Starlink Mini
I didn’t permanently mount mine since I also use it on our RV. However I wanted to be able to power it off of house dc with a nicely located outlet and on/off switch I installed near the rear helm on my 31s. I just run the power cord from the jack up to my roof rack where I have a mount for the mini. The previous owner had dc power already run to my cockpit starboard locker for a refrigerator I removed. Thanks to Glen Wagner for the tip on this approach.
That's a super clean solution. I might copy that. I installed a new Starlink Mini today with a 12V plug that up-converts 12V to 24V and has a female socket for the Starlink cable to plug into. Not as robust as this solution - but for now it works.
Motivated by Leo Goolden of Talley Ho fame (see Sampson Boat Company on YouTube) or follow this link:
We mounted our Starlink Mini on top of our radar dome using more or less the same techniques that Leo outlines in his video.
Similar to Leo, we have found this location to be ideal. No interference from the radar in our internet connection and no interference from the internet connection on our radar. We hardwired a 30v DC power supply and switched it on the panel with a custom rocker switch like Tristen T.
View attachment 26909View attachment 26910View attachment 26911
This is awesome. Can you provide more information about how you ran the wiring/cables for the Starlink and the other aftermarket antennae you installed on the mast?
In the R23, we routed the Starlink power cord following the same route as the radar cables, nav light, AIS GPS antenna, and WIFI antenna. It's a pain but welcome to Fluid Motion... Remove teak overhead panel in cabin, remove teak port hole panel on the starboard bulkhead, remove the refrigerator, remove the aft teak panel in the head.
The other antenna you see on our mast are for our Vesper Cortex AIS Hub (Garmin). We figured since we had the boat torn up to route cables, we might as well get all the new cables routed. The taller antenna is GPS, the smaller is the WIFI booster, in addition to these features, the Cortex has a hailer and automatic horn features. You'll notice we mounted the speaker/horn under the radar. We added a remote speaker near the helm as well as the handset for the system. See below.
Thank you so much. My Starlink mini is mounted on a pole that locks into the port transom fishing rod holder, and then I just plug it into the same outlet that powers the grill. I flip the "grill" switch on the AC panel to run the Starlink when I am on the boat. As a permanent DC solution, yours is the best I've seen yet.
We have an RT27 and purchased a 8 inch aluminum post mount from Amazon and drop it in a rocket launcher attached to the bimini supports. I also purchased another cord with positive and negative leads on the free end which we attached to a scotty plug and plug it into the downrigger plug. It works great. When under way we take it out of the rocket launcher and set it on the cockpit floor. It works great under way as well.
Steve
We decided on getting a starlink mini at the last minute and just strapped it to the back seat with a single bungee cord. Worked fine for us, even while underway. We used it between Anacortes and Glacier Bay National Park.
