CruisingElvinRay":3rooz72c said:
My R-23”s maiden voyage was 2,800 miles from Kent, WA to Pensacola, FL. Shipped by the factory on the factory trailer. No engine crutch.
That means that the factory ships the boat with the engine not supported. Nothing more. If they transported without supporting the motors hydraulic system they are not following Yamahas recommendation " If the motor can not be trailered in the normal running position an additional support devise is needed to support the engine in the tilted position" This is from the owners manual that you all have from Yamaha.
Yamaha does not want the stress put on the hydraulic system while trailering down the road. They put this disclaimer in their manual so that if there is a failure to the hydraulics and the motor falls to the full down position without enough ground clearance they are not responsible for the damages.
There is a misconception of what a transom saver is. A devise that is used to support the hydraulics is a trailering devise that should be called a Hydraulic saver. It really does nothing to support the transom.
I usually agree with BB, but disagree with the statement that the transoms weren’t designed for trailering. I would think FM would recommend Transom Savers if that were the case, but they don’t.
I think you read my post wrong. I don't see a quote "transoms weren't designed to be trailered" This is my quote"
BB marine":3rooz72c said:
The transoms are designed to support the weight and forward forces of an outboard not the vertical forces. When driving down the road, especially with bracket mounted engines or engines extended off the main hull the vertical forces are greater.
No where did it state transoms are not designed to be trailered.
If a boat on a trailer is tied down correctly with the proper hull support, a transom saver mounted and secured properly to the trailer, supporting the engine correctly there can be no argument that is not protecting the equipment and reducing stresses on the transom.
The threads question was
KKRCRACE":3rooz72c said:
Would it be wise to use a transom saver support bracket that goes from the rear of the trailer to the lower unit on the outboard ?
My opinion is yes. Is it required by a manufacture that has no idea what the conditions of the transoms will be in 10 years of trailering their product. No it is not required.
Today with the popularity of outboard 4 strokes and the use of pod or bracket mounts. When the boat is in the water the pod is evenly supporting the engine. The pod or bracket have flotation of some form. When that same boat is on the trailer the support ends at the trailer bunks. The weight of the pod plus the full weight of the engine is hanging out there completely unsupported. Look at the picture Brian 27 OB posted. The motor and pod is traveling down the road with close to 800 lbs hanging unsupported. Is it going to fall off ? No! Is it causing stress points that are weakening the hull where the pod and hull are bonded. I hope not! Are there additional stresses at those points when trailering down the road. Yes! I have looked at a number of R27 and R23 Ranger outboard boats out of the water at a dealer that is located where I dock my boat. I have seen crazing cracks at radiuses where the transom and pod meet. This is not surprising. Fiberglass flexes and gel coat doesn't flex as much. Areas in hulls and decks that have stresses it is not unusual to see some crazing cracks. There is repetitive flexing of the fiberglass hull or deck and then the gelcoat cracks start to appear. Most of the time these cracks are superficial not structural. In high stress areas like transoms I have seen structural damage from repetitive trailering without supporting the engine. The manufactures that used wood in the transom were more prone to structural weakness . How many older trailerable boats have you seen with metal plates bolted to the transom??
Just because a manufacture that builds a boat doesn't say use a transom support while trailering the boat.It is not wise to do! Boat Manufactures build boats. What happens to that boat 5 or 10 years after being built doesn't effect them.
It is not good Marketing to build a boat and put a disclaimer on your product. USE A TRANSOM SAVER WHILE TRAILERING TO PREVENT DAMAGE TO THE TRANSOM!! That is the last thing you will ever see from any manufacturer. The first thought a consumer would have is "They must have problems with their transom"!
Manufactures let consumers make their own decisions. My opinion and decision would be use a devise to support the engine to reduces stresses on the transom. Right or wrong!
I have had this discussion with boaters in the 70's,80's,90's ...... 2021 Transom savers are still made and used. Why?
