Underwater Lights Cutwater28
CaptainDavid
Cutwater 28
Sapphire Day
My underwater lights do not work and I need to know if bulb replacement is something my diver can accomplish. And, before I do that, where is the fuse, just in case that might be the issue. Thanks.
Greetings,
Certainly not an electrician; however, from reviewing the C28 Manual it seems we can get close to your answer. The link below will let you download the manual.
download/file.php?id=259
Page 37 schematic shows the underwater lights as being fused at the Sub Panel 3 Switch (20 Amp). Page 11 shows the 3 Panel Switch fuse block being located behind the carpeted panel below the main power panel and is labeled as such in the manual.
Hope this helps,
Gary
Gary, I looked in there and had trouble identifying the precise fuse. I'll check again before I jump to bulb replacement. Thx
David
David,
The photo on page 11 of the manual shows the exact fuse location. It's titled "3 Switch Panel" in the manual. I believe it is located on Fuse Block 3.
Also, the same fuse serves your deck lights. So, they the deck lights are working that fuse should be OK.
Gary
