Gunner065
- May 21, 2020
- C-26
- FMLR2516B010
- Off Watch
Good day folks,
So after a comprehensive review and research of available electric toilets and space available to upgrade, I have settled on the Dometic MasterFlush 7160. Installation looks straight forward and I'll mimic the piping setup I currently have.
Although I'm pretty handy, the electrical component (e.g. adding a 25 amps circuit breaker, running the lines to the head and grounding) has me a bit puzzled, as I want this to be as safe as possible. I'm not worried about the piping and fastening the toilet to the deck, it is fairly straight forward.
Here's what I believe must be done, please correct me if I'm wrong:
1. Turn off all power and disconnect shore power
2. Gain access to the AC/DC Panel
3. Install the new circuit breaker in a spare slot and wire as per installation manual
4. Run a red (+) marine wire (10-12 AWG) from DC breaker to the head to supply power
5. Connect switch/toilet motor & macerator to the red (+)
6. Connect toilet motor & macerator to a new yellow marine wire (10-12 AWG) (-) and route/connect to the nearest 12 volt ground buss.
Or do you run a duplex electrical cable from the AC/DC panel to the head, use the red wire for (+) and use the black/yellow wire for (-), but where in the panel do you connect the black/yellow (-) wire to?
