Morelords
- Jun 21, 2021
- C-30 CB
- FMLT2907G920
- Miss Calculated
Hi all,
For those with the Volvo penta D4 with the reverse gear transmission, model HS63AE-C, how much ATF are you able to extract: the full 4 quarts per the manual, or a little less?
I’m only able to extract a little over 3 1/2 quarts (maybe like 3.7 quarts). I am using a JABSCO oil change pump with 1/2 inch OD poly tubing (suction side) stuck down into the dipstick port. There is still a little bit of oil in the suction and discharged tubing, and the oil level was probably not at the max mark on the dipstick, but not minimum either.
Thanks in advance!
-Mike
Thanks in advance!
-Mike
