Washdown raw water system not working
Dmullen
C-32 CB
Selah
For some reason, my washdown system (Live Well, etc.) is not working on my 2018 Cutwater 242. I've checked the fuse at the switch and in the fuse panel. Is there a switch/fuse in another location or something else I should be looking at?
Hi there,
If the fuses are good, then it might be the pump itself. You can remove the leads going into the pump itself and power it with any 12v source. If the water line has nothing in it, the pump should run immediately. That will tell all. Hope this helps.
Cheers!
Ralf
