snydzy
- Jan 29, 2015
- R-25 Classic
- FMLR2517L213
- Tugster
I wanted to give a heads up on a recent problem we encountered while traveling on Kentucky Lake. We had stopped at a marina for fuel and a pump out. The problem was that their pump setup didn't have enough room to connect to the vessel's waste outlet on the back of our 2013 R25SC. The older R-25s have the outlet facing more out, while the newer 25SC have the outlet on top of the transom and some pumping setups can't clear the railing. Our attendant finally was able to use a flexible rubber nozzle that pressure fit into the opening while he held it by hand.... Not exactly ideal! As a solution, I purchased a cast 1-1/4" 45 degree elbow that threads into the waste port, allowing better access in case this happens again. I considered pvc, but thought it might break if stressed too much, and that just wouldn't be pretty! Has anyone else had this problem?
Regards!
Regards!
