Looking for proper procedure for pumping out waste water tank. Apologies if already answered in another place and my searches did not locate it. I did not find anything in my manuals or online. Here is the question....Is it as simple as removing the waste pump-out cap, connecting the suction hose and opening the suction valve in the pump-out hose?
2018 R23 with seawater flush, A/C and factory generator. Also have a Macerator pump but valve is off.
I pulled up to pump-out station the other day and performed a pump-out. Lever on toilet moved to the right (shut off) and this was my first time pumping the 11 gallon tank out since I purchased. I believe the tank was empty when purchased and I tested the toilet flush procedures and demo''d with my wife. Also no odor at all like I have read about. The attendant showed me how to watch the clear section of the hose and explained when the flow stops or is sporadic, the tank should be empty. It only took few seconds so I was pleased to confirm the tank contents were low. I thought now we can use the toilet if needed. BUT when I went down below I noticed the shower floor was wet. It was wet around the toilet. I open the seat and the toilet was full of water. Pump, open valve to left, pump pump pump and finally down to empty and then normal. WTH???
Luckily I think it was all seawater (river water actually). Hose down with fresh water from sink and pump out with shower pump. Dry floor and scratch head (on shoulders). Started searching for procedure....nothing! Okay, is the vent clogged and/or do I need to closed the seawater intake valve that is near the aft starboard side of generator? I'm thinking would they build it that way? Open center lid, kneel down, reach back to shut off the valve? Now remember to turn valve back on when down?
I read there could be a screen in the vent hose for the waste water and the fresh water tank vents. I will try to flush those next time I am at the boat. The boat spent four years in SE Texas before I purchased and am pretty sure they have some huge bugs down there. I know here in the NW we have bugs too. Bees, spiders, elder bugs, stink bugs and the worst are the mud daubers. They will pack small to large hole with mud nests. I have seen them pack the small round hole of a flat trailer wiring connector and other holes as large as a tail pipe, like a vent pipe in the roof of your house.
So again, What is proper procedure from the manufacture?
