mourinor9177
- May 9, 2019
- R-25 (Outboard)
- FMLT2542E424
- Ladyann
how does one get access to water tank sender on RT 25 outboard 2024.
Finally got to look. There is a wall just over the fuel tank and I do not see any screws to remove it. Unable to see beyond the wall Can this wall be removed , HowCenter cockpit hatch. Look forward once inside the hatch. Very easy access
My marina tech lost the part he took out. It was the sensor for fresh water tank how long is it so I can order a new part as they come in different lengths. If you have a part number or brand that would also help. ThanksMy apologies, I had it wrong. The water tank sender is accessed through the Mid-berth. The very front board can be unscrewed and you can see it on the right side.
