Markh":2hhi3gnq said:Thanks Bruce,
Just to clarify, you are referring to the fuse located in the head behind the mirror?
Hamster":2vrtefpf said:The temperature you set on the heater may be less than the actual temperature. When that happens, all you get is the fan. Make sure the set temperature is higher than actual.
