Webasto maintenance
baz
Subject: Webasto maintenance
According to https://www.webasto.com/fileadmin/w...umentation/australia-heating-air-top-faqs.pdf the heater should be run periodically...
"...as a preventative maintenance it is recommended that the heater should be run for 1 hour once every month regardless of the season."
Do others with the Webasto follow this recommendation ?
I also note that the above reference indicates the combustion air be externally sourced. On my R-27/OB I'm assuming one of the three vent ports on starboard side provides the external sourced combustion air.
We have not done this per schedule but our normal usage is probably at least once a month during the summer. It does not get used i the winter as the boat is in the garage.
