Subject: Webasto maintenance
According to https://www.webasto.com/fileadmin/w...umentation/australia-heating-air-top-faqs.pdf the heater should be run periodically...
"...as a preventative maintenance it is recommended that the heater should be run for 1 hour once every month regardless of the season."
Do others with the Webasto follow this recommendation ?
I also note that the above reference indicates the combustion air be externally sourced. On my R-27/OB I'm assuming one of the three vent ports on starboard side provides the external sourced combustion air.
