Where to position a Thru Hull transducer for a C302/C32c
Rocky Lou
C-302 C
Sea Suite
I've been advised in past that a:
Garmin B175h Bronze 20 Degree Thru-Hull Transducer - 1kw​
or similar sized transducer should be positioned forward of the second step. Kindly advise where specifically you recommend the install to take place, i.e. port, starboard, distance from step, etc. and confirm the method to access that area.
I need a high performance model for offshore fishing and want it placed in the best and safest position. Transom mount is not an option for me.
I had a number of conversations with a local marine electronics dealer and they continue to say, 'ask the boat builder, they'll know'.
Bumping...kindly advise.
Hi there,
We place our transducers on the 302/32 in the shower sump compartment below the access panel in the vberth floor. It is located behind the shower sump box. Hope this helps but let us know.
Cheers,
Ralf
