BB marine
- Feb 1, 2016
- C-26
- Non-Fluid Motion Model
- Grady White 208
- PORT-A-GEE
tranmkp":259gzggb said:Late on this trread ~ regarding engine loading and life
I was told this by several Volvo car and Mac truck reps regarding the Volvo turbo/supercharged engine. I was curious about the reliability compared to the red/silver blocks. Remember these are 2 liter engines putting out ridiculous horsepower. There is a lot of case pressure. Told the the engines are fine for suburban use but are having issues in mountainous states - blowing seals from lugging them up mountains
Marine engines area always climbing a hill. This is the reason they should be propped correctly. The engine needs to be loaded asper manufactures recommendation. The engine should turn 4150 rpm to be loaded properly at any rpm. Anything below 4000 rpm WOT the engine is climbing a mountain!!! If you run at 2000 rpm all day long but your WOT rpm is 3800 rpm You are climbing the mountain in over drive lugging the engine. The D3 is a good little motor. It is not a heavy duty truck engine. Propped correctly and used at 30 to 40% load propped correctly you will be boating for years!
