Garmin 5.9 Update
Andrew Custis
Staff member
Factory Employee
It has finally arrived. For all of you out there with Garmin units and a Yanmar 150hp or 260hp, this update is worth the download! I have been working with Yanmar and garmin for a long time to find out how to display oil pressure on your garmin chartplotter. Well this update will correct that issue! They have put together some software that makes this happen. They have also added some more user friendly features to the garmin autopilot functions. Click this link to download and update your chartplotter to the latest version.
https://buy.garmin.com/shop/store/downl ... 8&pID=9158
We did it the day after it came out on Larry's new R 29 . It worked perfectly and was very impressive with the data available on any screen you want it on . Technology marches on !
Andrew, what have they done to enhance the display of information for Cummins engines?
Sounds great!!!! Is there a procedure that works for Mac OS X?
Andrew: Thanks very much for posting this info.
Hey Bruce: Could do as before and take the *.exe download and create the SD card on your PC for me ? As you know, I'm a Mac family and have no personal WinPCs around.
Barry,
Send me a PM with your mailing address and I will mail you the one I used to update mine.
Unfortunately, Garmin is way behind in accommodating OS X users in their Marine division. You can't even download a firmware update without using a WIndows machine, even though agnostic download tools are pretty common. Nor can you run their excellent new desktop application "HomePort" which allows you to create routes and markers at home for later use on your boat. Last time I contacted them I was told they've created a team to work on porting Marine products to OS X, but no timeline was forthcoming.
Those of us in the OS X world can keep the pressure on. Contact Garmin Support and ask them to support you substantial investment in Garmin equipment.
  • US: 913-397-8200
    US Toll Free: 1-800-800-1020
    Canada: 1-866-429-9296
Meanwhile, if you don't have access to a windows machine, PM me with a mailing address and I'll start a list of folks so we can forward a card around.
Cheers,
Bruce
Does the Garmin run on a Linux OS ?
I ask as the largest file /Garmin/gupdate.gcd (some 280.7 MB in size) in this update is a Unix executable file.
/Volumes/1GB-STICK/autorun.inf
/Volumes/1GB-STICK/Garmin
/Volumes/1GB-STICK/SGPortable
/Volumes/1GB-STICK/SGPortable.lnk
I managed to download and copy the files to a USB memory stick on a WinPC laptop running Win XP Professional. I then transferred them from this USB memory stick to a 1GB SD card using my Mac Pro.
I then was able to dig out from the dusty draw a USB-to-SD card dongle. So inserted this into the WinPC laptop's USB port and was able to direct the Garmin unzip process to this and was able to get a completed SD card without using my Mac Pro. I will check the card out this weekend to see if it will update my Garmin software on my R25. I'll post back the experience. 😉
Garmin adds the following best practice for doing the software updates
-An SD card with 300MB of free space is needed for this update.
-Please back up your user data before applying the update.
Was able to find the changes Garmin made from version 5.2 to 5.9 -- for those interested.... 🙂
Note the Yanmar support changes made between version 5.80 to 5.90 -- Confirms what Andrew indicated. 😀
Change History
GPSMAP 5212 software version 5.90 as of May 28, 2010
Changes made from version 5.80 to 5.90:
Added support for outputting cross-track error over NMEA0183 with up to three decimal places of precision.
Added support for outputting MARPA target tracking messages over NMEA0183.
Added support for Yanmar engine tilt and oil pressure.
Changes made from version 5.70 to 5.80:
Corrected defective map drawing
Changes made from version 5.60 to 5.70:
Improved autopilot and chartplotter synergy
Fixed NMEA2k output bridging behavior with multiple 4xxx/5xxx units on a network
Fixed issues with map sharing between networked units
Fixed 3d chart issues near anti-meridian
Fixed 2d chart issues when zoomed out near Canary Islands
Fixed display of cranes on charts
Fixed display of intertidal heights on charts
Corrected issue that caused some map areas to be shaded incorrectly. This issue is most likely seen as large areas filled with solid brown.
Changes made from version 5.50 to 5.60:
Added support for BlueChart g2 and g2 Vision version 11.5.
Changed safety shading control to be a user data entry field.
Added support for Portuguese fishing areas.
Added support for dolphin buoys
Added support for using built-in map update SD cards.
Added support for synchronizing Auto Scroll speed with networked chartplotters and GSD22.
Fixed issues causing slow and incomplete tide calculations.
Modified to silence AIS Lost Target banner if the AIS Collision Alarm is turned off.
Display Date/Time when scanning Track Points.
Improved lost AIS target time calculation.
Fixed bug where waypoint names were drawing incorrectly on map.
Changes made from version 5.40 to 5.50:
Fixed shutdown with VEU706L map card near southeast coast of England
Changes made from version 5.30 to 5.40:
Added a control to turn off the AIS/Marpa Collision Alarm
Fixed issue where AIS targets with status of moored or anchored were showing up as lost prematurely
Added an 'Auto' option to the light sector control
Added a control to hide waypoints on the weather charts
Fixed bug where animated current arrows were displaying relative to North Up even in Head Up mode
Improved Mariner's Eye 3D operation under slow speeds
Added improvements to animated tide and currents to use smaller symbols and to draw them at higher zoom levels
Added the blue and black direction lines for orthogonal photo points
Corrected sonar noise rejection control to work properly in dual frequency mode
Fixed bug where zoom level would change when editing a route
Added ability to make sonar and video fields go to full screen in combinations by using rocker pad (4xxx only)
Fixed bug where Mariner's Eye 3D safe depth wasn't correct the first time you went to that view
Fixed shutdown when using the system information 'Save to Card' feature
Potentially dangerous points along auto guidance paths will be outlined in red. After the auto guidance calculation completes, a message will appear if there are potentially unsafe areas along the path
Fixed a bug where auto guidance lines can ignore the safety buffer on the first leg of the route
Changed the nature of seabed areas to simply label the area instead of drawing a circle and label
Updated the symbol highlighting on the chart to use the correct symbol size
Added support for calibrating Airmar DST sensors via NMEA 2000
Changed the water speed value that is sent via NMEA 2000 to be the calibrated water speed
Fixed issue where depth soundings were not drawing
Add ability to configure custom units in startup wizard
Fixed issue where maps created with Greek, Cyrillic, Easter European, Hebrew, Arabic, or Turkish writing systems won't display the proper text.
Changes made from version 5.20 to 5.30:
Added support to inform user of recalled map data.
Added sonar noise reject control for use with GSD22 with compatible software.
Added support to enable MARPA in sentry mode.
Added compass tape to navigation chart, fishing chart and radar overlay.
When a route is activated the unit will automatically add a leg from the boat's current position to the first waypoint in the route.
Added local weather to navigation chart point selection menu.
Added route turn distance and angle information to turn scanning text.
Added disclaimer to radar fields when in simulator/demo mode.
Removed duplicate entries from marine and offshore services list.
Added support for depth contour labels in fishing chart for older maps.
Consistent handling of multiple county warnings.
Fixed a bug where inter tidal areas were not being displayed on fishing charts.
I updated my Garmin 5212 from v5.2 to v5.9 today. It took 5 mins to update the Garmin autopilot and another 5 mins to update the 5212. It installed without issues.
With the engine ignition key in the accessories position the Yanmar data was shown to be available. I setup a "Combination" screen display to show the Yanmar digital data in the right hand side black bar -- see photos below. This black vertical bar normally shows only GPS Speed, Depth and GPS Heading. By tapping an area in the black bar below the "GPS Heading" a blue box appears and one is presented with "Engine 1". Press/tapping "Engine 1" will then list all the Yanmar engine data that is available. Select the one you want and it will display below the "GPS Heading" digital readout. One keeps doing this until all the black side bar is occupied with Yanmar digital readout data.
The last "Engine 1" -> "Fuel" readout I opted to display was the "Remaining" fuel -- not a very good readout IMO. 🙁
Note that a full screen display can be setup to display all the "Engine 1" data in digital or analog form (round dials) if you want that. I forgot to capture a photo shot of either of these. 😉
I cranked the engine up to ensure the Yanmar engine dynamic data displayed correctly -- and it did. 😀
This digital Yanmar engine data on the Garmin display screen in the right hand side vertical black bar sure beats having to stoop down and squint at the small square Yanmar stock display -- especially in bright daylight.
One note -- The Yanmar "Engine 1" available data indicated the Trim information could be displayed. However, I was unable to get it to display anything, even though it displayed a side view of a boat silhouette with trim tabs deployed -- shame if it's not available -- maybe others can post back the error of my ways... 😉 Is this "Trim"/"Tilt" related to an engine that tilts maybe ?
he7tnh
ehx6mv
0kb4ol
Barry,
Great tips!!!!!
Thanks!
Some of those tips came from Andrew who happened to be IN Canada no less delivering an R-29. That guy should have his pay doubled IMO. The critical advice from Andrew was for me to put the engine ignition key to the Accessories position.
I am not sure that I could disagree with Barry on this one! Great idea!
Help!!!! I have tried to download the update to a SanDisk 4 GB chip and either I am doing something wrong or the computer is not reading the chip. The chip is in an unlocked position and the green light shows, but it won't accept the update. Any ideas on what I can try?
Nita :roll:
Nita :roll:
Windows or Mac OS X? Garmin does not support OS X - booo!
I have windows XP.
Nita
Nita :roll:
What is the format of the 4GB card -- it should be a MS-DOS (FAT16) or maybe a (FAT32) format.
I just tried an 8GB Kingston SDHC card and formatted it MS-DOS (FAT32) and the Garmin updater wrote to the card successfully.
The Garmin updater will create a folder at the card's root level named Garmin and within this folder there should be a file named gupdate.gcd with a size of 274,149 KB. This file is a Unix executable and is what the Garmin chart plotter requires to perform the software update.
My system is Win XP Professional Version 2002 Service Pack 3.
Also, don't encrypt the card. If your MS Win system insists on encrypting it just uncheck that box and click OK.
If you're still having a problem I can bring over my SD card tomorrow sometime as you are but 2 miles from me.
The SD HC (high capacity) 4gb card would not physically insert into my rather new computer or my D700 Nikon camera... Got a plain vanilla SD 2gb card (not HC) and it went like gangbusters...
Don't know if the 5.9 upgrade added anything to my Garmin 4212 operating system that I need, but it probably can't hurt... I turned it on after the upgrade (at the dock) and it looked just like before, but does say 2010 and 5.9 on the information screen so I assume the update loaded...
Nita :roll:
Nita, call me or stop by the plant. We'll put it on your chip or you can borrow mine..
Howard
FYI...
Andrew told me the "Engine 1" -> "Tilt" function is not applicable for the R25. It's used my stern drive engines that tilt.
