serendipity
- Mar 7, 2024
- Marion, MA
- R-27 (Outboard)
- Serendipity
We used a king sized topper to make our v-berth topper in our 2023 R27 OB.
It's easier to tuck a sheet under a soft 3" pad.When you folks speak about mattress toppers, that means you are dropping a new mattress or memory foam over the factory cushions? Why not remove the factory stuff and replace with a thicker mattress or piece of foam? My plan is to remove the upholstery and foam components of the v-berth and retain the boards so I have a rigid base under the new 4" memory foam. I'd appreciate comments/thoughts. I've never done this before... What am I missing?
Five years ago, I had an upholstery shop add 1 1/2” of memory foam to the existing cushions on my 2012 R27. There was enough excess fabric on the cushions so the extra foam did not require replacing the fabric.Why not remove the factory stuff and replace with a thicker mattress or piece of foam? My plan is to remove the upholstery and foam components of the v-berth and retain the boards so I have a rigid base under the new 4" memory foam. I'd appreciate comments/thoughts. I've never done this before...
We have a 2025 R27 and a California King topper worked for our DIY foam topper. So if you are debating between queen and king definitely go with the king. We did not cut much off the length and barely any on the port/starboard sides closest to the bathroom and coffee station.Can someone tell me if I need to order a king or queen Costco topper for modification for our new 2022 R27?
