Mount Bracket for dinghy motor
Hensch42
FML2722H324
LEONCITO
IMG_1292.pngI have looked almost everywhere as to where to purchase the mount …. Any suggestions?
Outboard rail motor mount at Amazon, numerous ones available at around $40
I assume he’s referencing the entire unit including the stainless tubing, not merely the plastic square.
Thx for the comeback…. Yes, my interest is in locating the tubing.. really the whole thing if so available.. it’s a three legged tubing, which I believe it will not cover up the lettering.. I’ve looked @ Amazon & couldn’t locate one.
Any good local stainless welder in your market could make this for you based on your measurements. Probably a bit more $$$ but it would be custom fit for your boat specifically.
I believe Bolton Stainless in BC makes nearly all the stainless railings for Fluid Motion. They are Wholesale only but perhaps a call to Fluid Motion would help in case they had some of these made for them?
Yeah, I did. Then had a response from Fluid Motion Parts, & they are to research, since many parts are sourced by various manufacturers. No update as yet.
Very interesting approach.. certainly a reasonable priced project.. thx
Friend with a 2021 r27 says his boat had it the mount like the one in the picture installed when he got the boat. It was around $450 at that time.
I’m guessing the design is the same on new boats too.
I would not doubt it’s more that now.. everything from them is way up there, like 500% upcharge. the approach of getting the ttube holder from Amazon, as suggested earlier look like a way to go.. all I need now is to find someone that could bend to shape the 1” tube, or get a tube bender. I’ll keep on trying - have to find somehow how to carry a small outboard.
I bought that exact mount last spring. I purchased it from Port Boat House in Port Alberni BC, they ordered it from FM.
It was about $1000 CAD all done, including professional install. I had bought a different mount prior and didn’t like its single mounting point versus 3 points this one uses, so I returned the other one. Happy I did. This one works great and is solid without having to fiberglass the inside of the transom beyond what FM already does stock (in a R27).
The cost of this mount installed was more than I initially expected, and if I were to do it again, the price was much closer to what a good electric motor costs - which doesn’t need a mount and doesn’t require carrying fuel. I might have chosen the electric had I better diligenced the cost
But this is a great mount
