Yes, most high output usb-C cigarette lighter power adapters will run it. I believe the voltage on those is 20v. It also works great plugged directly into my Ecoflow high output receptacle.Ours is plugged in to the cigarette outlet on the command bridge. Runs no problem off that. if the cord is 10 ft and heavy guage I would try that first before bothering stepping the voltage up.
Also keeping it portable allowed us to take it in the truck on a trip in the back country and it proved useful to have when we were out of cellphone coverage for a week. In the truck it fits between the sunroof and sunshade with the cord dangling down to the cigarette lighter.
This was a pre-made cigarette lighter cord from starlink...., whether they have a built-in booster or not I do not know.Yes, most high output usb-C cigarette lighter power adapters will run it. I believe the voltage on those is 20v. It also works great plugged directly into my Ecoflow high output receptacle.
There are many versions of this available on Amazon. I chose to use one without a cable at all and just wired it to a panel mount barrel jack that would accept the standard Starlink connector. Here’s one with a socket included that you can plug the standard cable into.I can't picture it, but where is the fuse block on the upper bridge? Asking as this device has a fairly short power cord - otherwise, looks great. Thanks.
Hi jacrider, I found it under the helm and just a bit toward the port side. There are two prewires. One marked “Outlet” and one marked “Spare.” Not sure at this point how long those wires are, but I will probably need to replace one and a ground with longer wires.I can't picture it, but where is the fuse block on the upper bridge? Asking as this device has a fairly short power cord - otherwise, looks great. Thanks.
