guidothesquid":34eqznpo said:Don't forget you are also escorting total newbies through the locks. 🙂 I'd much rather use the small lock, and I think we'd be early enough to do it. We were watching the locks a few weekends ago and they were opening the small lock for only one boat. So assuming its not busy we should be good... As Sunny is well practiced at saying "it'll be fine. Everything is fine.", as she flies by the seat of her pants... 😉
Paul & Sunny: From last years experience it will be best to dock in at Shilshole where we can have someone board our boat at Dock X. you two will be just fine as there are two of you and if we use large lock you can raft/attach to my boat. I did this last year and it was totally successful. Bob (Nellie Two) came with me and handled one end (the bow of course) of our boat. We will use either lock which ever shows their green light first. Be sure to have 2 50' lines just in case. They need not be expensive lines... just something to temporally to hold you while your in the lock. The 2x 50' lines are needed in the large lock only if you're against the wall, otherwise you will be rafted and rise up or lower down with the boat you're rafted to.
Weather isn't looking good for Wed/Thu this coming week, plus we are in the midst of having significant minus tides at Edmonds... I think the one on Friday morning is at -2.6 feet at low tide! Weather permitting my plan is to leave Edmonds at close to 9am as we can with the tide level at close to 0.0. Tide will reverse just before 11am.
